zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.08.2007, 06:00 PM
What epoxy did you use then?
The heat build up on the tep FET's... like I said, any power bursts will have a larger temp differential than the average temp difference, so higher thermal transfer the better. But it is harder to do the top set i guess. The best way would to just use the case I designed really. You just apply thermal paste, and slide in on and clamp her down, there goes all heat sources down the sink. :005: HEAT sink that is.
