zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.09.2007, 02:52 AM
They probably were talking about inductance? At higher frequencies that are present in these BL controllers, inductance must be noticed and accounted for.
Also, flat wire (or flattened copper pipe), buss bar, whatever has lower inductance, and resistance than round wire. This is because inside the wire (round), there are self induced eddy currents which turn into heat.
But no doubt your setup should perform very well, i am going to have to use the same setup for a while with the clamp thing, until I get the case machined.
