SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
06.11.2007, 01:32 PM
Get a new rotor for your HV. It will solve all heat and current problems.
@Serum, I think I will end up testing both systems. Are there larger than 20 tooth pinions for mod1, because that's what I would need for the 8xl to even reach 50 mph in the buggy im getting. Novak claims their HV 4.5 can do 60 mph in a 1/8 buggy and I only need a 12 tooth pinion for that. I'm probably going to go with two max amps 3000 mah 4s packs in parallel. That should be enough since it takes less than twice the power to get a 1/8 scale moving as fast as a 1/10.
Area 52 Ranch Raceway
T.R.C.R.
