Thread: NEW Pics!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.11.2007, 10:43 PM
Originally Posted by suicideneil
Ingenious I reckon. I am assuming there were no real problems with fitting the rear A-arms on backwards to the tranny, as it were. Also I forgot to ask- is it stock wheel base or extended, bearing in mind the tranny is reversed.
The A-arms are, in fact, on forwards. The entire rear assembly is just flipped around. Normally the shocks are in front of the A-arms. The wheel base is extended due to the FLM front bulkhead by 5mm. Also as you recall I mentioned above that the RCM-RC chassis required you to drill two more holes behind the stock mount. My current design retains this feature which gives an additional extension of 20mm to the wheel base.
