skellyo
skellyo's Avatar
06.12.2007, 08:19 PM
Originally Posted by BrianG
If you are going to use 2.2" tires, the added weight and overall "gearing" because of the added tire diameter, I would go with the 4600 on 3s and use a 12T pinion. Even then, things may get hot.
Nope, no plastic spur option yet.
I'm not sure if you were responding to my post or not, but I don't plan to run truck sized 2.2's, nor 3S in mine. I'll be using a Trakpower pack and the stock tires.
