06.13.2007, 12:29 AM
7xl or 8xl should do the trick. You could get the MM if you plan on going no higher than 14 cells and I'd use the 8XL to keep the current down. If you may go with more cells or 5s lipo, I'd get a Quark 125B. If you want a better quality motor, you could go with the Neu 1512 2.5d. It will stay cooler and still have tons of power.
