Originally Posted by zeropointbug
Sorry, I meant 35 amps through two rails (18A rails).
You can combine the rails as well.
Are you sure you can combine the rails? Most of the dual 12v supplies I've seen are seperate and go to different sections (like one 12v line for all the drives and the other for the mobo). I paralleled one once and one of the switching transistors got very hot, very fast. I would only do that if the specs say you can, but that's just me.
