MetalMan
MetalMan's Avatar
06.13.2007, 01:03 PM
You should be able to see the pic. now, I made a boo-boo.
Hook up a resistor to your Lipo pack and drain it to zero volts. Then they can be disposed of.
It wouldn't be difficult to remove two cells from your 5s2p pack. You should be able to continue using your current balancer with the 4s setup, but how the taps would be wired depends on the balancer you have.
