AAngel
06.13.2007, 11:05 PM
What are you going to be running this in? It sounds like a boat setup.
In any case, it's kind of hard to tell what a nemesis motor will do, because Fine Designs is rather tight lipped about the specs of their motors.
The Nemesis motors are just relabeled Feigao motors, with a different color can. I'd just find me a Feigao motor so that I could be sure of what I was getting. Besides, you'll pay a bit less for a Feigao. I know that Fine Design guarantees the bearings in their motors, but good luck cashing in on that one.
In my limited experience with boating, I've found that the Feigaos run pretty cool, with the water cooling. If you are going to be running this in a car or truck without water cooling, you'll need to be more specific about your proposed setup.
