Thread: Revo E.E video
Cajun
06.15.2007, 04:59 PM
Originally Posted by E-Maxx King
What are your settings on the MM? Every setting. What gearing are you running? What kind of runtimes are you getting? And hot is the setup running? If the outcome is great then Im sold on this setup. But im going to put this in a e-maxx for now with dogbones.
Well, since you asked so nicely....:rolleyes:
Gearing is 18/38
I'm getting about 20 minutes of track running, slightly more bashing.
With that gearing it's running about 130* ESC & motor.
You're going to need more than just dogbones for an E-Maxx to handle that set up and you're numbers are going to be different unless you figure out the exact same gear ratio for the E.
Here's EVERY setting....
