06.21.2007, 10:22 PM
Well, technically, you may be fine. It depends how long the motor will be at max rpm. If you are doing speed runs, the motor will reach max rpm and stay there longer, and will be prone to overheating. If you are racing, you probably will not reach top speed, and if you do, it won't be for long. Like I said, the generally accepted rule of thumb is 35000 rpm max. This comes from many users' experience.
