RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.16.2005, 06:27 AM
I have had very good luck wit the TRX 2.5 motor. If you follow the break in and don't try too hard to tune it (a little goes a long way), they are good running, reliable, fast motors. The Traxxas motor do tend to run a bit on the hot side, though. Aways have. The RDLogics high end pipe is pretty impressive with the 2.5 motor.
If you hop up the motor, OS is the way to go. I have the tm .18 in my Revo. OS motors run like champs and hold a tune extremely well. The TM is a direct fit, while the TZ may take a little lovin to get into the Revo. The TZ is also a bit of a handful without a chassis extension.
Daniel,
I have the .27 broken in for the most part. It seems to run/idle very well(though I did replace the glow plug with an OS #8). I will give you some more info after the weekend. It seemed to run a bit warm yesterday(250), but not out of control, and it was HOT! I will let you know how the weekend fairs with the motor.
