remie
remie's Avatar
06.25.2007, 04:34 AM
Originally Posted by Eccentric
Waterjet or laser cutting?
Looks like a solid design. Not much to critique. I would be a little worried about the offset of the front and rear holes on the lower plate. Not that is should be a problem cutting as much as strength.
What is your planned layout for electronics?
Are you going to be supporting the rear of the motor some how?
I'm going to let it lasercut
de offset of the holes on the front and the rear lower plate have changed in de last desings.
for electronics, in de front there will be one steering servo, on the other side there will come a tekno reciever box.
for the esc I will make a plate that I can attach on the side of the TVP's
I don't know if I'm going to support the rear end of the motor.
Would the rc-monster motor clamp help to support the motor?
Costum Traxxas revo Brushless
  Send a message via MSN to remie
