NiCad
R/C Racer
NiCad's Avatar
06.25.2007, 10:18 PM
I got a 7" buffer wheel set up. I polished this up. Two passes on the cutting side and two on the polish. I plan to spend a little more time with it and the most likely have the dremel on the back side to finish it up.
Got the Battery mount laid out. I plan to do the machining this week(end). Then polish it as well.
looking into making a hold down mount. Attached is a rough sketch. I was thinking these would be pretty trick. Mount at top and back. Bottom is not for sure. I hate drilling holes in the chassis. Plan to to do four of them for the battery mount plate.
If I do not attach the hold downs to the chassis I prob lose that leg all together and have a L bracket so to speak.
Any ideas or things you see that might not work please do not be shy.
Thanks,
NiCad
ID:	3145   Click image for larger version
Owens Racing™
CRT.5 B/L
Detta ST B/L
RC18(diggity LHO) B/L
Detta Buggies Brushed Bashers
