supralover72
supralover72's Avatar
06.26.2007, 02:01 PM
When I did this, The motor and the esc were both pretty cool, but the esc was 5 degrees hotter. Here were the final results:
ESC: 90.6
motor: 85.5
EDIT: Ok, fixed one major problem. Found out how to disable the BEC and did it. Seems like it helped out with the heat issue a lot. The thing I'm worried about now is the whining/grinding. It also looks like I have a bent rear center universal, but I can't tell for sure.
