IBJAMMIN
IBJAMMIN's Avatar
06.26.2007, 08:15 PM
The main diference between brushless and nitro is the power curve a nitro motor builds power with RPM where a brushless motor can have almost full power at any given RPM the nice thing with the Mamba ESC's is you can go in and change and manipulate the throttle curve on your computer to mellow it out and make the car more controlable and easier to drive this also helps extend the life of the diff's and gears by reducing the power at lower RPM's. It's a lot easier to detune the power and have it where you need it then wish you had more?:017:
