06.26.2007, 08:20 PM
^^ True that. A 10xl on the MM with 12/14 nimh would be great- the more winds the slower the motor on the same number of volts. The advantage being you can always get a quicker motor later to go faster, as you get used to the speed/torque. The MM will only safely do 14cells with a ubec.
