06.26.2007, 10:21 PM
The problem is that all my trucks are running fine temp-wise to notice a difference. I would have to run it on a certain day at a certain temp, install the caps, and then run it again with the same conditions to see if there is a difference.
The only heat trouble I have is the CRT.5 running the 4600 motor. I guess I could throw a couple on there and see if that helps, but I plan on getting a 1930 and Mike agrees with that choice.
