06.27.2007, 11:25 PM
I would just search until you find it. It'll probably be in the "brushless" section. Not to sound lazy, but I don't wanna search all night. :)
Basically:
  • open the case
  • GENTLY seperate the ESC from the case (there are thermal sticky pads)
  • remove the heatspreader slab
  • clean the FETs and case where the pads were
  • cut a piece of 1/8" thick aluminum the same length and width of the old heatspreader (the old one is too thin to do the mod)
  • use thermal epoxy (Arctic Alumina adhesive) to secure the heatspreader to the FETs
  • let harden
  • epoxy the ESC/heatspreader to the ESC
  • let harden
  • put the case back together.
