07.20.2005, 10:40 PM
The bearings are 5x11x5mm if you need to replace them Once the cans pop, they tend to keep popping. The heatsink will cure this for sure. As dafni said, the popping can sometimes cause the rotor to damage a winding on its way out. I wouldn't run it without some security, or you risk doing permanent damage.
