BlackedOutREVO
08.30.2007, 12:53 AM
You may be right, but it is the 45 mm wide kb motor, not a 35 mm wide feigao. It is 62 mm long, so not as long as a 540xl. It should have plenty of torque, with a big rotor like that. I would have bought the xl can but it was out of stock at the time I ordered. The 10000 4s pack is only 95 grams heavier than the 8000 4s2p pack. Also ithe 8000 is taller than the 10000 pack, 50mm compared to 32mm. The length and width are not a problem as I am making a battery tray out of lexan anyway. Plus the main reason is the 10000 pack is free cause I have it and the 8000 pack would be 240 even with my discount. Also not too fond of packs that have cells in parallel, can't balance all of the cells to each other, only pairs of cells. I know that a 2s pack rarely goes out of balance but i am picky with my lipo charging and maintenance.
Well then
That sounds like a good set up!
I didnt know you had the lipos already... And I want to hear how that motor will work out
Make shure you keep us updated
