rchippie
rchippie's Avatar
09.01.2007, 10:01 PM
Originally Posted by crazyjr View Post
What you see in that link is Steve's current swaybar setup, The rear sway bar is mounted on the rear bumper mount on the bulkhead, My concern would be someone rear-ending me and bending the bar
Larry it is not mounted off the bumper. the kit i saw which will most likely be the production set, be cause is had the traxxas name on it in risen letters was mounted on the rear plate were the tie rods are mounted. the same bolt mounts the rear swaybar mount & the rear tie roads.
REAL MEN RUN BRUSHLESS
