crazyjr
crazyjr's Avatar
09.05.2007, 12:21 AM
Originally Posted by rchippie View Post
Larry it is not mounted off the bumper. the kit i saw which will most likely be the production set, be cause is had the traxxas name on it in risen letters was mounted on the rear plate were the tie rods are mounted. the same bolt mounts the rear swaybar mount & the rear tie roads.
I was refering to the link in post 12, I'm sure Traxxas will do it different. Personally i don't see a need for a swaybar, I have not seen a situation where i would need a swaybar unless its blacktop
