mkrusedc
NeuMaxx
mkrusedc's Avatar
09.05.2007, 11:32 PM
Figured it out. I was over voltage at 14 cells.
Spaz123 said "are you using 12 or 14 cells? After the controller is on and ready to go, is just the yellow LED on or are both the red and green LEDs on? If both Red and Green LEDs are on, you are over voltaging the controller. Try running it off of 1 pack just to see if it works.
When the controller is armed and ready to rock just the yellow LED should be on if everything is ok.
The reason i know this is because my friend just got his controller and had the exact same problem. The give away was that the red and green LEDs were on."
Could some one explain this? I thought the MM could run 14 cells?
