lutach
lutach's Avatar
09.06.2007, 10:40 AM
Just came back from running the truck with the MM. Well let me start by saying the weather was a bit cooler than yesterday's run with the MGM. It is around 74 degrees and everything was just perfect. I ran the truck for over 10 minutes and stopped for a while, because of a spectator LOL. The MM was warm and the batteries was around 90 degrees. Now I said everything was just perfect and that "was" is due to the darn DPR-II-150 not recording the run at all. Came home, plugged it to the USB port, opened the program and got slammed with a "No mission data available". I wouldn't mind if the truck wasn't performing good, but it was just too good of a test that this had to happened. The Aveox took a beating and it was hot after the run. This truck did some nice wheelies, full throttle and hard braking. Tomorrow I will run it again and hope that the DPR will record some data.
