09.12.2007, 09:31 PM
If the screws are 10mm long, they shouldn't go beyond the gear face. I don't know why they would but how much space is there between the screw head and the clutch? If it's just a little, I'd use a washer to take up the slack (really shouldn't matter) so that you can remove the screws if you need to.
There should be no clearance issues if you remove first gear.
