09.13.2007, 10:30 PM
Remove the ring gear, and then all the internal gears. I would clean everything out and start fresh.
A little trick I found that makes cleaning the smaller spider gears much easier is to use an air compressor and blow the oil off. Just use needlenose pliers to hold it in place and also use a napkin or something behind it or the oil will get all over you. :)
