Patrick
Patrick's Avatar
09.22.2007, 01:49 AM
Using the same number of the same type of cells (2x 5s1p or 1x 3s2p + 1x 2s2p) the total weight should the same. There might be a slight difference in the amount of wire, depending on how it's done, but it wouldn't be noticeable.
I think the best thing about using 2x 5s1p packs instead of a 3s2p and a 2s2p would be the balanced weight.
Cells in parallel should balance each other, so it shouldn't be much different I wouldn't think.
