Thread: BL Xray M18!!!
lutach
lutach's Avatar
09.23.2007, 09:23 AM
Lutach, what is happening to the viscous diffs? Are you stripping the ring and pinion or the spiders? I fixed the spider issues in mine and good shimming helped the ring and pinion. A lossely set center ball diff, like the mip will help the diffs last lonnger. I had TLT wheels and tires on my mlst and I think that they had a hand in killing my diffs!
The first set I stripped the ring and pinion and I had it shimmed. Now the second set the internal gears seems to be all garbage. The plastic is too soft. I'll try the ball diffs to see how they act. I think I got my M18 dialed again. I tried 6S lipos to see if the ESC could take it and it did. This ESC is just amazing. I might work on a mini to set a speed record.
