09.27.2007, 07:01 AM
bump, still having this problem played with all sorts of settings with no luck, anyone got any suggestions? some more info if this helps
Anyone got the settings they are running with thier quark neu combos?
From Eagletree recorder
Peaks of 135amps
Motor doing max 43,000rpm (this seems to be when it cannot apply brakes close to or at max rpm.
geared with 14 tooth pinion and stock spur
THanks
