09.28.2007, 05:38 PM
i wanted to use kyosho spur with shaved teeth instead of the metal gear but the spur is just too tight and i needed to put it on/off too many times during making the holder and it was annoying. so thu spur ended up as gear holder.
having one piece unit would be very nice but thats long term run to find someone which machinery thats able to make it.
if the diff helps in handling i will probably make the metal gear holder and maybe shave off teeth from the bevel gear (they just add few grams of weight as look does not really matter as its hidden inside tranny)
just wish i had more space at home to get better equipment for work with metal
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
