rhylsadar
rhylsadar's Avatar
09.29.2007, 10:24 AM
hi
let me see if i got this right. this chassis above will take the normal gp axles of the savage. doing this will bring us in the weight range of the usual gp to ep converted savages, which is about 2-4 pounds more than the e savage.
so then i should put a e savage center gear box in there instead of a modified savage gp center gear box right? this center e savage gear box has plastic gears and is designed to transfer the power of two 550 brushed motors in a light 9 pound e savage. and now it should transfer the power of BL setup for a converted gp savage, that weights about 50% more and is equipped with a big neu and 16 cells or the like?
...The drivetrain will take what you throw at it for sure...Especially when mated with the GP front and rear diffs...
wouldn't the e savage center gear box then be clearly the weak spot in the whole tranny?
i might be wrong but and one could try it but i would be very positively surprised if this works.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
