10.03.2007, 06:39 PM
Are you still goinf with the magnetic brake drum idea was it, or something different- I think some kind of disc brake mounted on the rear shaft would be good provided you could fab a hub/mount for the disc, then you just have to build somewhere for the pads to mount and then link them to a brake servo.... sounds so much easier when you type it, but building it is somewhat harder me thinks..... good luck!!!
