10.03.2007, 11:58 PM
If you mod the mgt spurs to fit the xl5 slipper you have the best of both worlds. The stock slipper sucks for a heavy/over-powered pede. I use the xl-5 slipper with jato spurs and 32p pinions and have not had a single problem. The mgt pinions just need the ctr hole enlarged to use the xl5 bearing, and 3 of the "peg holes" opened up to fit over the bolt bosses on the slipper hub, 2 minutes with the drill, at most!
