lxmuff
lxmuff's Avatar
10.04.2007, 05:52 PM
Do you have a pic of the cooling setup you have?
MGM is putting the fans on with their controller. One 25 mm fan on my MM cools better than no fan on the MGM with the same setup. The MM has 36 fets on their board while the MGM has 2 x 36 fet boards if people didn't know. The cooling fins are poor on the MGM and a larger more eff. one would go a long way. MGM must have noticed later that their controller in some conditions(my racing) would require better heat rejection.
The idea of the MGM was to not have to use fans for me. I know others feel the same way.
Originally Posted by wallot View Post
My mgm overheated when imporperly mounted in truck after like 10 minutes of running in grass (esc recorded 105 degrees C) after mounting it to aluminum angle bolted directly to the flm chassis no problems whatsoever.
