10.04.2007, 07:46 PM
I like that write up Brian, its one of the simpler little projects that even I could manage (probably).
Anyway, since ClodMaxx already has the novak fan I would say do the following:
1. If you have a spare slot on the rx, then just extend the wires (if need be) so that it can plug into the rx- it only draws a tiny amount of current so wont hurt anything.
2. If there isnt a spare slot, make one by using a short Y-splitter on either the throttle or servo channel so that the fan can plug in and the esc/servo rx plug can too.
There should be a spare slot though for a bec or rx batt to plug in so use that one, but sometimes this is doubled up as the channel 1 slot. Makes no odds though, just plug the fan into the rx and its good to go.
