mkrusedc
NeuMaxx
mkrusedc's Avatar
10.04.2007, 08:52 PM
52t mod1 Associated gear and a 17t pinion.
Thanks for posting that Neil.
Sorry GorillaMax360, I have not checked this thread in a while. I was worried about the gears meshing because of the Neu hitting the tranny so measured the distance between the tranny input shaft and the motor shaft. I then used Brian's gear calculator to come up with the gears. I had to use the Associated gear because I still have the stock slipper. I have a stobe on the way so i may try some different gear ratios in the future.
Here it is: http://scriptasylum.com/rc_speed/_gear_calc.html
