Thread: My kliiMaxx
Hotti
-Bash till it's broke-
Hotti's Avatar
10.07.2007, 01:19 PM
Hehe...ok neil..now even I get it
But but..
I had some major problems with esc at the beginning..
First it worked ok(the very first run).Then i tryed to programmed it to use with nimh cells.When i put nimh's on and turn the power on esc starts to beep beep beep....beep all the time.Even i put the default setting in it still beeped.
But when i had put default in about ten time in row it started to workin ..Now if i have run with lipos,i programmed it with lipos to use nimhs.then when i have drived with nimhs and want to use lipos i program it with nimhs.This way it works perfectly.Love the esc.
First i programmed it with transmitter, but now i have usbcom+ and CC02 cable so I can do it now with pc Much easier and safer.
So..
I have had problems with rear driveshaft's..they wont hold on..wonder why ..Well..i had revo some time ago and had some parts left on it.So i modded revos drive shaft to fit my kliimaxx on the rear..Revos are much stronger,hope that will hold.
Pics with mod maybe tomorrow.
Emaxx,FLM,Integy,MGM 16018,Maxamps,Lehner 1940/7,Futaba Fasst
