GorillaMaxx360
GorillaMaxx360's Avatar
10.08.2007, 05:14 PM
with a lower total overall gear ratio should i expect less temps from the motor or more. for example i want to run a 49t spur gear and a 20t pinion but i have 1/8 buggy diffs instead of stock maxx (ratio) diffs. with the same calculations as mkrusedc except different diffs and spur and pinion my ratio comes out to be 13.95662 : 1 and his setup comes out to be 14.99346 : 1. does this mean i can expect hotter or colder temps out of my Neu. and if so would it be a small change(like about 10 degrees F).
