10.08.2007, 07:53 PM
I asked this question a while back; the answer is no. Arthur (griffinRU) explained what the problem is with trying something like that, but there is a solution. He calls it the stage 2 modification to the MM esc. You basically bolt two power boards together which have the FETs mounted on them, and then bolt the MM brain to them; this has the effect of doubling the amp handling from 100ish to 200ish amps constant, but it does not increase the voltage handling- he is working on a version 3a & 3b to do that....
