A123 Low Voltage Protection ?
marc993turbo
A123 Low Voltage Protection ? - 10.09.2007, 12:44 PM
Hi there!
I am using A123 packs (2p3s) cells with my Brushless Maxx and Savage.
I am looking for a good low voltage protection since the lipo protectors are not usable with the A123 cells because of the different cut-off voltage...
The A123 should habe 2.0-2.1Volt and the common lipo cut off would be around 2,5-3,3 Volt.
Not very compatible...
The only good ESC for the A123s is the Schulze 32.170 i am using since the ESC calculates the cut-off value based on a percent value of the voltage it measures if the pack is connected with the esc.
Are you guys using Low voltage protection for your A123 packs at all?
Help would be nice.
Marc.
