marc993turbo
10.09.2007, 04:27 PM
Originally Posted by AAngel View Post
In my experience, the packs dump long before the minimum voltage is reached. The only way that I can see hurting an A123 pack is if you accidentally leave it plugged in and the servo just sucks it completely dry.
... thanks for your replies!
I think i am a little bit to cautious when it comes to lipos and fepo4 since my experiences with the last generation nimhs were bad enough...
...drain them a few seconds too long and - buff, the next run the cells have 200mAH capacity less.
So i read all the horror storys about those sensible new technology power cells and became to cautious...
But it seems for me that the fepo4s are much less sensible than the last generation nimhs.
Till now the fepo4īs are running very well.
But the best for me is the way i can charge the cells: put them on my schulze isl 8-936 and puff - they will be charged with full 10Ampere current in a few minutes!
Two packs of A123s and i can run as long as i want!
That was the way i wanted to run my rc cars which was not possible with nimh cells...
So i will take your advice, run till they drop their voltage and stop.
thanks!
Marc.
