10.13.2007, 08:51 PM
The 10amp hr batteries are big, and heavy. It would fit in a ls10 but it would make the truck side heavy. The 5k or 6k 3s packs would most likely be better. PM if you want the motor, I sell it for less than 50 bucks. It is in great shape maybe 2 hrs on it, probably less. You will need 5mm bore mod1 pinions. You can get them from mike at the rcm store, he is the fastest and most reliable. I run mine with the stock servo and itis fine for bashing. You may want to disable the mm bec and run a ubec or receiver pack. Just depends if the mm runs to hot for you. Not really necessary on 3s.
