BP-Revo
BMW M Power!
BP-Revo's Avatar
10.14.2007, 06:17 PM
Putting some shims between the teeth and the bearings will prevent it from sliding back, while putting shims between the bearing and the outdrive cup will prevent it from moving forward.
Naturally, the way the diff works the pinion is pushed out, so you really only need to put shims between the teeth and bearings.
