10.15.2007, 12:10 PM
At first glance it looks very nice. I do have a problem with the mesh adjustment though. The stock Nitro motor sits a bit under the spur gear, so the angled up/down adjustment of the stock setup works well. However, the Techno mount makes the pinion sit to the side of the spur. The stock mesh adjustment will still work, but won't have the adjustment range that Mike's mount does by far.
The 5mm shaft requirement is not a real limitation because you can get bore adaptors. The new bore reducer line-up Mike has are really nice and strong.
The battery tray is nice though, but should be 6061 IMO simply for strength.
