crazyjr
crazyjr's Avatar
10.16.2007, 01:19 AM
How on earth did you break a tooth off the input gear??
Are you using the stock 2 speed? Or the GM single speed conversion?
More information will be needed... have you taken apart your tranny to look at it?
Sounds like he was using either 2 speed or had the 1st gears taken out and the flex caused the steel gears to crash wrong
