10.18.2007, 11:05 AM
Quite alot of new parts, looks good to me! I will have to get one as soon as they are available!
Did you guys see the twin velineon setup they had! Wonder how hot that got during testing!
If you look in the accessories section the single motor plate and gear cover looks very interesting. The fact that they are there means that there will be a single motor 4s vxl emaxx soon. I do not see a 6s system coming out from them. It may have the capability, but we all know that a motor that is optimised for 4s is going to spin too fast and run hot on 6s. Unless they make it 5s compatible, that would be more likely. Something similar to an 8xl would run fine on 4s or 5s. Plus it would be setup to run some sort of off-the-shelf nimh pack. This new emaxx takes 7 cell packs, and that is what traxxas are setting all of their specs to. It will be slow on 12 cells, wonder if that evx2 can handle 16 cells? They do list a bigger battery hold down as an option!
