chilledoutuk
10.23.2007, 03:16 PM
if you want to solder the motor directly to the esc why not just remover the bulltet connectors and solder directly to the esc board.
I would however recommend that you just shorten the wires as its not easy soldering the tabs on the mamba max unless you have a very powerful soldering iron.
