ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
10.25.2007, 03:22 PM
Will the wires on the MM ESC be thick enough to fit inside the 5.5mm connectors? On the wires from the MM on my 1/8 buggy, the wires seem very thin... which is why I directly soldered them to the motor.
seems this question went unanswered. i soldered 5.5mm bullet connectors (bought from mike, by the way ) to my MM leads. the opening of the connector is certainly larger than the wire, so i 'twisted' the bare wire up and crammed it into the hole so it took up the spare space. heat it up, add solder through the handy hole (wasn't meant for that i know, but it sure was handy) and viola.
Eflite Blade 400 heli on 3s
