DrKnow65
DrKnow65's Avatar
10.26.2007, 01:17 AM
Lincpimp, there will be two fans, a pusher and a puller fan. The board will be standing up vertical with a sink on the left and a sink on the right. The brain board will be on longer wires to make space for the heat sink. So the air will be flowing thru both heat sinks equally. kind of like a tunnel with fans at both ends and the power board standing up in the middle.
You can get a better idea of what I am saying if you look at the wiring setup in my previous post.
I do plan on stepping up the voltage and motor, just in small increments.
